Group: DynoMotion Message: 11049 From: Colin Fera Date: 2/8/2015
Subject: CW/CCW vs quadrature
Is the kflop quadrature output the same as CW/CCW?
Most of the lead shine drives and their clones seem to have a jumper that can select for step/dir or cw/ccw.
Would this be a way to use the lead shine drives without violating the 5us Direction Setup Time?
Colin
Group: DynoMotion Message: 11050 From: Tom Kerekes Date: 2/8/2015
Subject: Re: CW/CCW vs quadrature
Hi Colin,
No I believe CW/CCW is separate pulses for each direction, where quadrature is two signals 90 degrees out of phase.
Step/Dir can be converted to CW/CCW steps with 2 "and" gates and an inverter.
Group: DynoMotion Message: 11051 From: Colin Fera Date: 2/8/2015
I was searching for something unrelated and I came across this post (#2 down from the top):
Is this approach inadvisable?
-Colin
On Sun, Feb 8, 2015 at 11:00 PM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi Colin,
Group: DynoMotion Message: 11052 From: Tom Kerekes Date: 2/9/2015
Hi Colin,
I can't see how that could be correct or would work.  From the description from Leadshine below it seems clear they are expecting CW pulses and CCW pulses not Quadrature.
Group: DynoMotion Message: 11083 From: Colin Fera Date: 2/14/2015
Would CW/CCW be a feature that would be easy to add?
 If it were included then you could support the majority of leadshine drives without the caveat of a possible lost step on direction changes.
Colin
Sent from my iPhone
On Feb 8, 2015, at 23:00, "Tom Kerekes tk@... [DynoMotion]" <DynoMotion@yahoogroups.com> wrote:
Hi Colin,
Group: DynoMotion Message: 11144 From: Colin Fera Date: 3/1/2015
Would this work to convert STEP/DIR to CW/CCW: https://www.fairchildsemi.com/datasheets/74/74VHC139.pdf
I supposed I would tie A0 to direction, and A1 to step.  Then connect O2 and O3 to CW/CCW by connecting them to the opto isolator cathodes with the anode tied to ground. I would take these from JP4 and JP6 as LVTTL.
Colin
Hi Colin,
Group: DynoMotion Message: 11146 From: Tom Kerekes Date: 3/2/2015
Hi Colin,
I think that logic is correct but not the voltage levels.  The VHC series logic requires 0.7xVcc = 0.7x5V = 3.5V for a guaranteed high input.  KFLOP's 3.3V LVTTL outputs only guarantee 2.8V.  I believe the 74S139 would work.  They are standard 5V TTL that requires a 2V High input level and will drive up to 20ma (I think the Leadshine inputs require about 13ma based on the 270 ohm series resistance they show).   See:
Also I think the Opto Anode (+ side of opto LED) would need to be connected to +5V not ground.
